How do we get the CMPs to understand the real origin of over-driven staple fires?
mbrooke
Batteries Included
United States
Technician
Here is the crux of matter supporting AFCIs:
The above tends to be caused by current leaking into wood members for years if not decades via energized staples, nails, ect until the wood dries out into charcoal eventually igniting into a smoldering fire. Aka pyrophoric carbonization. The issue has been documented any time energized metal contacts wood for what ever reason.
The CMPs and many other in the electrical industry have been sold a very different etiological theory- one which is highly flawed- without any real world verification through investigation. UL's explanation being that over driven staples damage insulation such that a copper to copper air gap is created within the cable assembly. Repeated lightning strikes cause multi thousand volt surges which arc across said gap in turn creating a carbonized path between two conductors such that 120 volts can now arc across them despite voltage dropping to normal levels. Due to the circuit's impedance or breaker's age, the OCPD does not trip instantly thus resulting in fire from the incident energy cause by this so called "high current arcing".
What people need to realize is the those presenting supporting material to the NFPA are most gifted in phenomenology, as cheese as it may sound. Information is presented in such a manner (by the presenters) that the observer believes they have reached an objective conclusion on their own when in reality they infer what the presenters wants them to infer. No ones thoughts are their own.
How do we get this across to the rest?
