Genesis006
- Carmel, IN USA
- CEO/Electrician
What is the best way to wire a 600amp 3 phase service. What size conduit and wire?
Pretty vague question that has many possible answers. More details will narrow down some of those possible answers.What is the best way to wire a 600amp 3 phase service. What size conduit and wire?
You may comply with NEC with 3.5" but that doesn't mean a POCO or even local codes can't still require 4". Ask them for the reference to their requirement if it is beyond NEC. If they have a standard that applies to everyone then follow it. If they are shooting from the hip - good luck with other dealings with them.I am install a 600 amp 3 phase service. I believe I need two 3-1/2" PVC schedule 40 conduits with 300 mcm paralel feeders from the transformor to the 600 amp distrubution panel with # 1 ground. The reason for the question is, they are requiring two 4" conduits for future to PP-3 and PP-4. When I need 3-1/2 why wound they want 4"?
Over 2 inch maybe, 1/2, 3/4, 1-1/4, 1-1/2 are pretty common both pipe and fittings in about all types of conduit.Integer inch sizes of conduit are a lot more common, and a lot easier to get. Occasionally you may find fitting product families that mysteriously omit certain half inch sizes.
