on a100 amp residential sub panel is #10 ok for the ground or #8?
E enireh Senior Member Location Canyon Lake,TX May 4, 2016 #1 on a100 amp residential sub panel is #10 ok for the ground or #8?
C Carultch Senior Member Location Massachusetts May 4, 2016 #2 enireh said: on a100 amp residential sub panel is #10 ok for the ground or #8? Click to expand... See table 250.122.
C cbledsoe89 Member Location texas May 4, 2016 #3 Needs to be a #8 as Long as you have not up sized the wire to adjust for any voltage drop
al hildenbrand Senior Member Location Minnesota Occupation Electrical Contractor, Electrical Consultant, Electrical Engineer May 4, 2016 #4 What size is the feeder for the subpanel?
