Power Solutions
Ok, so I was called to provide an estimate for a generator installation.
When I arrived to the lady's home, I found a pole mounted 200 amp service (meter and main panel) and two feeders (one over head and one underground) going to the same manufactured home.
Underground 2awg 4 wire feeder was the original and connected to the feed through lugs at the bottom of the 200 amp panel on the pole and run to the panel in the home. (nice)
Overhead feeder was feed off a 100 amp breaker on the pole and run to an indoor rated panel on the outside of the trailer which then feed two 60 amp breakers for an electric forced hot air heating system. (more quality work)
I identified the code violations to the homeowner.
The "shoemaker" who installed this had his inspector come over and look at it. The inspector said the manufactured home could be feed by two feeders.
I think the inspector is incorrect (being polite) and do not see any wiggle room for interpretation on this.
Question: Does a pole service fall under 225.30 (More then one building or other structure)?
Is the pole a structure? Thoughts?
Dj
Dj
