NEC User
- Marlboro, NJ, USA
A client commented that one of their ceiling fans moves slower than it did about a year ago. Is there a reason why a ceiling fan would spin slower?
I'm pretty sure that anything that mechanically slows a fan down will eventually burn out the motor. One Halloween Party my daughter tied small tissue paper "ghosts" to strings taped to the blades of a ceiling fan which slowed down its rotation a bit, and after an hour or so the motor smoked and stopped turning.I would think that a lower voltage ( voltage drop, bad connection, bad switch ) would slow a fan down, or even a bad bearing.
How are they controlling the speed of the fan, pull chain or a speed control at the switch location ?
The cheapest repair is normally a new fan.
If it isn't the pull chain that had been pulled, it could indicate that the capacitor in the lower canopy of fan is failing or out of spec.
This ^^^^^
Just repaired one a while back that the capacitor had burned out. Had to put a complete new control unit on it as the capacitor was built in to it.
But the same problem can happen on an external cap.
To the OP:
I would either tell them to replace the fan or pay you to take out the old cap and try to find a matching one. When they find out the charge for troubleshooting is close to the price of a new fan they might just opt for a new one!
Shouldn't take much more effort labor wise to troubleshoot then to replace the fan, unless you don't know how to trouble shoot it.
Either way you are going to assess the problem on one trip and return to replace or repair on another trip. Figure out the problem and parts needed, tell customer the options and let them decide. Ceiling fan capacitors are not that hard to find on line, just search the number of the existing one and you usually will find one, they are not all that expensive either, but will require time to get them shipped and received. If you want express shipping (like next day air) you will likely be spending enough that a new fan is well worth consideration.
extremely dirty fan (air drag)
I had one like that once. 20+ years of crud buildup on the TOPS of the blades caused the fan to slow down, a LOT. The HO only cleaned where she could see it, there must have been 1/4" of crud on the top side of the blades at the trailing edges. I cleaned it off for her and it worked fine.
Wow, never seen one that bad. Was thinking too that a direction change could slow down the fan if there was enough gunk on the now leading edge (like pushing a brick thru the air instead of a knife blade).
I guess we are all in different boat.My point was that sometimes the old fans aren't worth the trouble of replacing parts and if you make it high enough for your trouble/time they might opt for a new fan.
I used to be able to pick up capacitors locally. But now only one place has them but not every type needed. So you end up taking the old one out, reading the numbers, (if they're even readable) then spending time online, ordering and waiting on the parts.
On top of that, if the fan is old and you replace just the cap to get it working and a short time later something else quits. The customer then thinks you either don't know what you're doing or trying to rip them off!
If the ceiling fan is like this:
http://camodernhome.com/collections/ceiling-fans/products/ar-ruthiane-wood-ceiling-fan
then by all means, repair it.
If it's like this:
http://www.wayfair.com/Hunter-Fans-...78&device=c&ptid=154612528620&PiID[]=12031378
the best way to repair it is to make sure it breaks when you throw it in the dumpster after hanging a new fan.
eta: as to why an existing fan turns slower than it used to; drag in bearings, loose blades causing more blade pitch and air drag, extremely dirty fan (air drag), could be many things not electrically related.
One of those two fans is the ugliest monstrosity I have ever seen.
Is one of these worth fixing?
