Magic Gorge
- Lexington, KY
When determining the circuit breaker ground fault settings for two or more tiers, should there be any consideration for the time gap between the delay settings? For instance, if I set my main at 0.4 seconds and feeder at 0.3 seconds, the curve sheet shows no overlapping. However, should the feeder be set lower to avoid nuisance tripping?
