4 bulb T8 ballast or other issue
Ponchik
CA
Electronologist
I having trouble figuring out why the 2nd bulb on this set up does not work when the 1st bulb is plugged in.
This was a double ballast T12 fixture so I converted it to single ballast 4 bulb T8 fixture.
When I installed the first T8 ballast, it was buzzing before turing ON, so I replaced the ballast, I checked my wiring about 4 times. I still can't get the 2nd bulb to light up when the 1st bulb is plugged in.
Any help is appreciated.
I have checked the sockets they are good,, I have relocated the bulbs and the bulbs are good. View attachment Document- 5.pdf
Ponchik
CA
Electronologist
I guess you are correct. But two ballasts bought from two different places?
I hate to, but I will try another ballast.
