First post here. I check the website everyday and have learned a lot from everything so I appreciate that. So my question is..... If you had 10 3/4" pipes going into a wire way and had to splice one circuit and the ground do you then have to splice all the grounds in the other conduits entering the raceway to? Assuming that all the other circuits are pulling straight through. I have heard it is a code but can't find the specific reference. You know how it goes everyone says it is a code but can't point it out...
