Rigid Metal Compression Fittings
360Youth
Newport, NC
I am looking for a similar part that was located for me by our supply house a couple of years ago for a job. It is a compression connector for RMC that can be used on cut conduit. They got me one similar to the included link, but this particular fitting is dry location and I need wet location (overhead, outdoor install). Don't know if I used the previous part incorrectly because was on a revamped service riser, or if there is an wet location listed fitting. Thanks.
http://www.garvinindustries.com/electrical-fittings/rigid-imc-fittings/compression-connectors/rt200
Thom
Sierrasparky
USA
Electrician ,contractor
Those type you speak of may have lost their raintight listing. Many EMT connectors are not raintight any longer without the plastic seals inside.
