Reduce the power required by the driven load?
It's the only way I know of...
But nicolaschalhoub,
In all fairness to someone who is obviously not an native English speaker, the terms you use might be getting in the way here.
"... it presents a lot of power which is harmful to its surrounding"
I'm not sure what you mean by this. If by "power" you are meaning starting
current, then what Golddigger said is one way to get a reduction. "Power" is kW, which is what is required by the load and supplied by the motor. The motor will CONSUME power commensurate with the requirements by the load. So if you don't like the power consumed by the motor, you will need to live with having the motor do less work.
