steve holt
- Hawaii
Is it allowable to install standard stamped steel boxes in concrete walls that are in direct contact with the earth? Based on section 300.6(A)(3) I believe it is because the box is zinc coated.
I bet that works well, and lucky for you there is sand in abundance; here there is mostly rocks. When we can't find rocks it is because they are covered with snow.I plug the conduits and pack them with wet sand.
