Robert Whiteaker
- San Francisco, CA
I am installing 120 volts, 208 volts and 480 volts to an A/C system. The two panels are right next to each other. This is an industrial business. I have always understood that the when you use 600 volt wires with different voltages that you can put them in the same raceway or gutter as long as the high voltage is not in a low voltage box with low voltage device. Am I wrong? Thanks.
