davidgarrett
- Greenville, SC
While working in a customer's house, I discovered each neutral has 120V to ground in the panel when disconnected from the neutral bar. I opened a few receptacles and switches to discover the same 120V on the neutrals there also. This is a ML 100A panel located in a finished basement being fed by a MB 100A panel located outside next to the meter. There is also a ML 200A panel next to it being fed by a MB 200A panel outside also. Everything in the house seems to be working fine and no breakers are tripping. I spent about 4 hours trying to figure out the problem with no success. I asked the homeowner to call the POCO to eliminate the possibility of it being a problem with the incoming service. Does anyone have any experience with this and can offer some explanation as well as a solution?
Thanks in advance for your help!
