powersupplyguy@netzero.ne
- Warner, NH
Greetings,
We have a control panel with a disconnect switch. We would like to remote mount a Hubbell 480v 3 phase 30amp Twist Lock Flanged inlet connector (HBL-2735)to the side of the machine and wire that into the disconnect. The Hubbell connector will be inside an enclosure and will require removing screws to access.
I would expect the problem to be that the complete machine will not be de-energized when the disconnect is open. The 10' or so of wire from inlet to connector to the disconnect will be live.
The application is a large printer. We manufacture the printers and ship worldwide.
Am I going to have a problem with the CE inspector?
thank you,
PowerSupplyGuy
thank you,
PowerSupplyGuy
