U/G wire pull
nizak
Was looking for a bit of advice on an underground pull. I have 3- 2/0 CU conductors and 1-#4 CU conductor (THHN) to pull thru 150' of 2" Sch40 PVC. Run consists of 2- standard 90 degree elbows, rest is straight line. I have access to an electric puller but rigging it at the house end would be quite time consuming. Does this sound like a pull that could be done by hand with 2 guys and a bottle of pulling compound? Any advice would be appreciated. Thanks.
RLyons
Sound like a home run to me. We are currently doing 8 unit apartment building ranging from 150' and under with the same wire and also going to a second floor.
cadpoint
Durham, NC
I'd make sure to blow it clear of water if it's been in ground awhile! A pipe full of water will slap back, even a good shop vac will do the job! Pull the end as you use the shop vac.
I might consider a foam rat after you clear water. A good thickrag head pulled through
mightbe a consideration.
If you put it in, and if you can, pull into the bell end of the run.
Maybe some warm up exercises are in order, spinning the arms, swiveling the torso. :D
Open telephones or walkie talkies are a most!
A third person might help the feeder of the wire. Then can only unrell about 10' at a time.
so your looking at 15 - 18 pulls. Two or three sets of pull, rest, work on rythme, if manual the puller works after the feeder, someone will fell the difference!
One, Two, Three - Pull!
ActionDave
Chief Moderator
Licensed Electrician
View attachment 9400 You forgot the helpful illustration. No worries.
  • Screenshot from 2013-12-05 21:49:02.jpg
cadpoint
Durham, NC
... You forgot the helpful illustration. No worries.
No, You forget that I use to get paid to draw. Some times I should stop.
or not at all...
?Words can be like X-rays if you use them properly -- they?ll go through anything. You read and you?re pierced.?
? Aldous Huxley, Brave New World
?Writing is like sex. First you do it for love, then you do it for your friends, and then you do it for money.?
? Virginia Woolf
I found a great quote looking at something else the other day that I could re-find...:D
