Razzap
Our manufacturing plant often uses 480 V 3 Ph transformers to feed new machines. Since this is a separate source, I need to run a grounding electrode conductor to a ground rod. Problem is, the floor is 18 inches of concrete, on top of 24 inches of gravel. Under that is dry soil. A ground rod or two will have very high resistance, in any case. The columns are concrete, the underground utilities are non-metalic, and all other pipes are above ground and fastened to the nearest concrete. No building steel is available anywhere. What will a high-resistance ground rod accomplish? Using the floor rebar is out of the question. These in-house machines get moved on a regular basis. The machines we build for customers will leave when they are completed. Cutting up the floor to access the rebar is not allowed, and even if it were, it would look like Swiss cheese in a few months due to machines moving in and out. Any suggestions?
