eddie_kerri
- cincinnati, ohio
I am installing (4) dedicated circuits and will be using MC Cable from the panel to each receptacle. I am using surface mounted 4 square boxes with 3/4" EMT that will penetrate a drop ceiling. Can I simply sleeve 12/2 mc cable down the 3/4" EMT conduit or do I have to use an mc connector, grc coupling and connector at the end of the EMT above the ceiling and strip the outer jacket at that point so only the conductors are in the EMT? I think I already know the answer, but I thought I would run in by everybody.
