131025-0935 EDT
pyro214:
As "charlie b" stated it is not clear what is your question.
If I assume from your name you are working with ovens or heaters, then these are likely resistive loads. To adjust temperature it is possible you are using phase shift controlled SCRs or Triacs to ajust power and therefore temperature.
I also assume that you are concerned with steady state current, and not a turn on transient inrush current of some sort.
The RMS current to a constant resistance load from a constant voltage sine wave will never be greater than the value obtained when full sine wave excitation is applied to the resistance. As you chop part of the sine wave away by a phase shift delay to turn on of the electronic switch the heating of the resistance will drop and that means the RMS current drops. You can write the equation for RMS current using the square root of the integral from T1 to T2 of a sine wave squared divided by time per cycle. Do this for a half cycle.
The integral of sin^2 x dx = x/2 - (sin 2x) / 4.
Assume turn off occurs at Pi and the time duration is Pi, and turn on is at K*Pi, where K ranges from 0 to 1, then
Irms^2 = (Pi / (2*Pi) ) - PI*K / (2*Pi) + sin (2*Pi*K) / 4*Pi
Irms^2 = 1/2 - K/2 + (sin (2*Pi*K) ) / 4*Pi.
For K = 0 (a full half cycle)
Irms^2 = 1/2, or the sq-root is 0.707 .
Turn on the sine wave at 90 deg, K=0.5, and the result is
Irms^2 = 1/2 -0.5/2
Irms^2 = 0.25, or the sq-root is 0.500 .
Thus, the RMS current for a sine wave on from Pi/2 to Pi, and 3*Pi/2 to 2*Pi is
0.5/0.707 = 0.707 times the RMS current of a full on sine wave as applied to a fixed resistance. If you design for full excitation current and the load resistance is constant, then reduced on time will not cause greater heating in the supply side than full excitation. A circuit breaker for a full sine wave will work with a partial sine wave.
Ckeck my math.
