You might want to check the manufacturers website. Some are rated for a variety of voltages and some have provisions to change connections for different voltages. All of the 240 volt units I have seen will work on 208 but some require simple alterations.
If it is a Switch Mode it should. If transformer rectifier not likely unless the transformer has taps. This is one question you have to ask the manufacture, not on a forum.
