Davebones
- North Of Tampa Fl
Have a machine that just came in . Engineer says they have to have 50 Hz at 40 amps 240 V . What would be the best way to get this ? We have 208V and 480V 60 Hz available in the plant now .
Investigate exactly what "the machine" entails.
Depends on the type of load.Also, you'll need a higher voltage at 60 Hz for that motor, not 240 volts.
