gary
- California
- Retired electrical contractor / general contractor
I recently installed three of the new Leviton AFTR1 receptacles in my 1977 era condominium. I had to slightly modify the existing wiring to position them as the first device in each of three circuits, but found I was able to provide AFCI protection for all of the bedroom and living room receptacles and all of the lighting circuitry. If this quote from a Leviton brochure is accurate, we will be required to install a lot of these in the future:"Leviton?s Smart lock Pro OBC AFCI receptacle can also be used to meet the NEC requirements for replacement receptacles that take effect in 2014.
NEC 406.4(D) states, "Arc-Fault Circuit-Interrupter Protection. Effective January 1, 2014, where a receptacle outlet is supplied by a branch circuit that requires arc-fault circuit interrupter protection [210.12(A)], a replacement receptacle at this outlet must be one of the following:
(1) A listed outlet branch circuit type arc-fault circuit interrupter receptacle
(2) A receptacle protected by a listed outlet branch circuit type arc-fault circuit interrupter type receptacle
(3) A receptacle protected by a listed combination type arc-fault circuit interrupter type circuit breaker."
Although something of an AFCI skeptic, I have to admit that it felt good to know that my 35 year old wiring was now being protected by this state of the art safety technology. That was before I found out that the AFCI protecting the circuit in my bedroom / home office / ham shack tripped immediately whenever I tried to use my 100 watt amateur radio transmitter. I found that transmitting with as little as 5 watts could cause the bedroom AFCI to trip! The cord on my transceiver is long enough to reach an exterior receptacle on another non-AFCI circuit and I was sure that would solve the problem, but again I found that a low power transmission would instantly trip the bedroom AFCI. I called Leviton and asked for a suggestion. A CSR suggested that I swap two of the AFTR1's to make sure I didn't have a defective device. That seemed like a reasonable suggestion, but I found it didn't alter the problem. The AFCI is apparently reacting to electromagnetic energy induced in the house wiring by these radio transmissions. I called Leviton again and talked to another CSR who seemed quite interested because he said this was the first time anyone had reported a problem like this. That was late on a Friday afternoon and they were getting ready to close for the weekend but he assured me I would get a phone call or email from someone from their engineering department on the following Monday. I never heard back from them, of course, but wanted to put the word out that radio transmissions from a nearby ham or CB operator can definitely cause these things to trip. Due to restrictive CC&R's, many amateur radio operators have been forced to use "stealth" antennas hidden in attics, under eves, or disguised as flag poles, so it may not be obvious that random false tripping is being caused by the ham next door.
