Cable slitter tool
jumper
I have multiple shielded and unshielded communication cables, 4 conductor #22 to #18, I install into a control cabinet. I needed to remove about 3' of sheathing on each cable.
Looking for a good tool to slit sheath. Something like this. Ideas or recommendations?
ActionDave
Chief Moderator
Licensed Electrician
The yellow thing. Not the green handled thing.
Aleman
Southern Ca, USA
I have the Paladin 1822 shown on that page. Don't know about the one featured on the page, but it might be the same. The blade can rotate 90? after making the circular cut and then be used to make a length wise cut. The length wise cut doesn't work too well but it does work. That's what I use for those kind of jobs anyhow. Other guys use the string that is usually inside the cable for that purpose. What the Paladin excels at is stripping SO cable for plugs etc. For a 3' strip, the string might work better.
