Conduit run with water pipe install above ground
I have a water pipe that the mechanics on sight want to run thru a transformer yard on an out door electrical pipe support is this allowable on a seperate support or not allowed at all thru a transformer yard
Gregg Harris
Virginia
Electrical,HVAC, Technical Trainer
Are you asking if the water line can be atached to the support system for above ground conduit like on Kendorf with hangers?
Gregg Harris
Virginia
Yes it is on Kindorf, 10 feet of the ground and 4 feet from transformers
They can both be supported fom the same assembly. Each could not be supported by the other, conduit supporting the water line or water line supporting conduit
