I'm part of a team installing packaging equipment, which has several control transformers all sourced from the same branch circuit. The secondary neutrals of these are all tied. An additional Y-Y transformer is to be installed (for a new machine feature) and is sourced from a different branch circuit. This will power a controller/equipment which has a 24VDC input to a PLC. The PLC is sourced by one of the original transformers. The team is struggling with determining if the new transformer neutral should be tied with the other transformers. Any opinions?
Thanks in advance for your help
