Troubleshooting a 6" recessed can in a soffit at a bank yesterday. Found a loose connection in the JB. As I'm working on it I'm thinking, "this JB is very difficult to access".
I'm not a real large guy and I have trouble getting my hand or hands up in there to work on it. 4" cans are near impossible.
I'm a one man show, so, I can't pick the "guy with the smallest hands" (although, I guess that would be me!!) to send out on the service call.
Just seems like a bad idea to make connections one handed and "by feel".
How the hell do you guys with "basketball player hands" deal with stuff like this?
i've got sixteen 4" low voltage lights i'm converting to LED's, so i get to gut and rewire them,
and they are IC type airtight units. about a foot square.
i'll let you know how it goes. i suspect it'll suck.
first thing is some cheap contact paper in 2' squares, the minimally sticky stuff.
paste it on the ceiling over the light hole, cut it out, and you won't end up with
hand prints all over the ceiling.
second thing is to make sure no hot wires are in the box... no feed thru hots.
what i'll probably end up doing is opening the inside cover, gutting it, and just
attaching my LED pigtail to the wiring there. as there is no heat present to speak
of from the LED driver, i may just bring the wires directly out and plug them in,
i haven't cracked one open yet to see..... lights are gonna show up in mid january,
they are back ordered on trims... these are nice architectural quality LED's, and
have a bayonet mount that allows the same LED driver to fit 4,5, and 6 inch trims,
so your light output is identical across all devices. 16 of them are $1,900 wholesale.
1,100 lumens each, your choice of color temps. full range dimmable.
honestly, it's tedious work, so rather than dive into it off a stepladder, i'm gonna
split my little giant ladder into two horses, and use my spiffy expando plank between
them, so i've got a nice place to sit, and a shelf to put stuff on... it'll span furniture,
and i can do two or three from one positioning.
if you drink, put a cupholder on it for a beer. this may take a while. you might as well
settle in and get comfy.
oh, and wago's. when i have snarky wires in sucky places, wago makes a lever action
wirenut that is the only thing worth playing with. you can slide them over the wire,
snap the lever, and they do NOT come loose.
http://www.wago.us/products/2631.htm
(these are the secret weapon)
they are also part of an integrated system, that works nicely in panelboards
and control applications.
http://www.wago.us/downloads/51011212.pdf
