Commercial Kitchen GFCI's
Nietz001
St Paul MN
Is it ever acceptable to install a 120v rec in a commercial kitchen that is not GFCI protected? I was told if the equipment (such as a refridgerator) is difficult to move or fixed in place it's OK to make it a single rec and no GFCI? Just doesn't seem right, looking for help.
iwire
Massachusetts
No there are no NEC exceptions for 15 & 20 amp, 125 volt receptacles in a commercial kitchen. Regardless of how hard they are to access they must be on a GFCI.
There used to be exceptions for GFCIs in dwelling unit basement and garages for dedicated appliance outlets and some folks thought they applied to all GFCIs .... they did not.
Now those exceptions are gone anyway.
infinity
New Jersey
Journeyman Electrician
Also the GFCI has to be readily accessible for testing purposes. That means a remote device or a GFCI breaker if the equipment cannot be moved.
I think the original proposal to include all 120 volt commercial kitchen receptacles was prompted in part by an electrocution involving a refrigerator and a bad/missing equipment grounding conductor IIRC.
Another thing to note is that most commercial kitchens have to deal with a health departmental authority. Alot of them require that food in freezers, refrigerators etc... be monitored. So if the power went off and the temp started to drop, the alarm should go off and one can save the food.
Dropping temp or rising temp?;)
I'd love in invest in that. I got $20 that's just burning a hole in my pocket.:D
Send your investment dollars to me, in any amount, $1, $5, $20, $100, or whatever you choose. I promise I will return you your share of profits I make in this particular venture:happyyes:
