As others have said, there are fires, and then there are FIRES.
IMO, any area that's getting stripped to the studs might need to be brought up to your current code. This means you may need to add circuits, distribute the circuits differently, increase the service size, add GFCI's and AFCI's, etc. It all depends on the intensity of the fire; a pretty mild fire can cover everything with greasy black soot, yet leave the drywall and electric otherwise undamaged.
Otherwise, as for the wire itself ... I would not 'automatically' replace any wire unless the outer jacket is actually damaged. A simple smoke stain is not 'damage,' IMO. Devices are another matter; you'll get corrosion within from the smoke, so all devices will want replacing.
The usual drywall and insulation we've been using for the past fifty years provides a pretty good fire barrier. It takes a pretty intense fire to actually damage stuff within the walls. Odds are, you had more damage caused by fire department operations (water, pike poles, etc.) than by the fire itself.
