- NE Nebraska
First of all the code says oulet , the CMP removed the word receptacle outlet.
Not all outlets have receptacles , however all receptacles are outlets.
That being said. Why only outlets in a dwelling within the conditioned space seem to need either afci , GFCI or both but outlets in an attc do not. I suppose a arc will not occur at a attic outlet.
See what we did not know is that ARC's and resulting fires are smart and know never to occur in a attic or crawlspace. :rant:
I don't have my 1999 and 2002 codes handy, but I am pretty sure when AFCI was introduced it never specifically said "receptacle outlets" and the AFCI rules applied to all outlets in the areas where protction was required. I remember the biggest confusion at the time was the smoke detectors are considered outlets and people were missing this fact and failing inspections because the smoke detectors were often on a different non-AFCI protected circuit.
AFCI's are going to be expanded. They started out in just bedrooms. Not only is there controversy over whether or not they do what the manufacturers claim, they were first just introduced for bedrooms, then somewhat eased their way into more requirements.
You can be assured the manufacturers will fully support their use on pretty much any branch circuit, and will continue to push for expanded application requirements.
If they do what they say they will do, it probably is a good idea. The jury is still debating that one though, and the consumer is the real testing lab.
