aftershock
- Memphis, TN
Installer was color blind!I know I am no where near being able to say I have seen it all. I have seen a lot, and I know for sure I have never seen anything like that.
A safety inspection was done on this house and it seems the inspector never went inside to check the main panel.
I'm with you. Can you imagine what's hidden in the walls? Someone should question the safety inspectors credentials.I know I am no where near being able to say I have seen it all. I have seen a lot, and I know for sure I have never seen anything like that.
We replaced the panel. Now the receps have reverse polarity once we corrected the way the wires were landed. This system started with a 100 amp service feeding a 60 amp fused pullout disco, then #4 thw hots with # 6 thw neutral (not in conduit) feeding this panel. The safety inspection (done by our code enforcement dept.) only cited the lack of a ground rod (which was a short piece of 3/8" all thread) and the illegally wired detached storage shed which we just cut loose.
You're a braver man then me. I would have walked way from this one.
It passed inspection, so I am told. After I had completed the job I had realized I did not put a main disconnect at the meter. I figured it would fail. The original rejects were just to install a ground rod and terminate the wiring in the detached shed/garage. Once I saw the panel, I figured the insp never went inside and told boss we need to correct this and my DA thought the panel was backed up to the meter ( I got turned around somehow when I looked at it), So I figured 1- 1-1/4" LB and 20' of #4 THHN, plus the panel. Well,,,,, 35' of 4/3 romex later and 3' of 1-1/4" PVC, I got the panel fed, but then realized than NM cannot be used in that manner, I should have installed a main at the meter.BUT IT PASSED. And we will not be getting paid for anything but correcting the defects the insp listed in the 1st place.
I checked out a house that had reverse polarity on about half of the receptacles. Pull them out to look at the wiring, they were wired correct. Looked inside the panel. On the right side of the panel: the white wires were on the neutral bar, the blacks on the breakers. On the left side of the panel: the black wires were on the neutral bar, the whites on the breakers. :?
What's the problem? That's what you call a balanced load.I checked out a house that had reverse polarity on about half of the receptacles. Pull them out to look at the wiring, they were wired correct. Looked inside the panel. On the right side of the panel: the white wires were on the neutral bar, the blacks on the breakers. On the left side of the panel: the black wires were on the neutral bar, the whites on the breakers. :?
