gar
- Ann Arbor, Michigan
- EE
121202-1531 EST
iceworm:
I have been thinking more on my black box analysis. Can you pick any holes in it.
If line voltage is constant, and I think that is the assumption we must make, then is there any normal type of load that as a result of increased efficiency of the induction motor would have a lower RPM than the less efficient motor?
Input power is watts to the motor. Output motor shaft power is input minus losses. Since the motor is more efficient that means more output power for the same input power.
Is it likely that the motor design criteria would be shifted such that more slip would occur at our operating point, but still have higher efficiency. I do not expect this would be a design direction. It would imply increasing the rotor resistance, and more than offsetting that increased rotor loss with a much more reduced loss in the magnetic circuit area.
My guess is that both magnetic and rotor losses would be reduced to gain higher efficiency. But I have not seen any comparative motor curves.
iceworm:
