121203-0827 EST
masterinbama:
I disagree with your comment.
If a load is a pure constant resistance, then increasing the resistance in series with that load and supplying from a constant voltage source will not increase the current. Rather the more added series resistance the lower the load current.
A pool heater is going to be a resistive device with some sort of modulator. Broadly this could be either a thermostatically controlled switch, a bang-bang servo. Or a temperature controlled phase shift current adjuster, a more conventional servo system.
The peak power capability of the heater should be great enough to provide the desired temperature under the greatest heat loss conditions. Probably this peak power capability, the power when the heater is full on, will really be greater than ever required. Thus, once the water is up to temperature the average power to the heater will be much less than the peak capability.
The major problem with voltage drop between the source and the heater is the initial time to heat the water, it will be somewhat slower, and if under maximum heat loss conditions the desired pool temperature can be maintained.
As long as the heater can do its job of meeting the average power requirements, then the series resistance does not matter. If there was an electronic control at the pool, then its minimum voltage to operate could become a factor.
The site editor messed up and my comments where entered before I was done. Going back and editing I may still be within the timeout limit.
