ENT
ENT
Smurf tube (ENT) and its cousins are sometimes used in other conduits to separate cables, especially telecom stuff. ENT is allowed inside buildings (some rules for fire rating and place of assembly). It is pretty sturdy, I can jump up and down on it without breaking or deforming it. You could pull empty ENT with the power conductors into the main conduit, treating it as a single conductor of its outside diameter for fill purposes. It also comes as a prewired assembly. Consider:
725.136 Separation from Electric Light, Power, Class 1, Non?Power-Limited Fire Alarm Circuit Conductors, and Medium-Power Network-Powered Broadband Communications Cables.
(A) General. Cables and conductors of Class 2 and Class 3 circuits shall not be placed in any cable, cable tray, compartment, enclosure, manhole, outlet box, device box, raceway, or similar fitting with conductors of electric light, power, Class 1, non?power-limited fire alarm circuits, and medium-power network-powered broadband communications circuits unless permitted by 725.136(B) through (I).
(B) Separated by Barriers. Class 2 and Class 3 circuits shall be permitted to be installed together with the conductors of electric light, power, Class 1, non?power-limited fire alarm and medium power network-powered broadband communications circuits where they are separated by a barrier.
(C) Raceways Within Enclosures. In enclosures, Class 2 and Class 3 circuits shall be permitted to be installed in a raceway to separate them from Class 1, non?power-limited fire alarm and medium-power network-powered broadband communications circuits.
Calling a raceway an enclosure may be a little stretch.
100 Definitions.
Enclosure. The case or housing of apparatus, or the fence or walls surrounding an installation to prevent personnel from accidentally contacting energized parts or to protect the equipment from physical damage.
A raceway certainly performs the function of an enclosure.
