2008 nec article 250.146 B
grumpy11
ok lets look at this. simple outlet in wall. 2 wire ac cable to box adapter ring on box. sheet rock wall,
useing self grounding device. does the device have to be bonded to box if there is no metal to metal contact from device to adapter.
infinity
New Jersey
Journeyman Electrician
The self grounding receptacle is permitted to be used without an additional jumper when screwed to a grounded metal adapter cover.
grumpy11
yes but does it have to be metal to metal . last 2 words in article. flush-type box.
that wpould mean metal to metal to me.
Gregg Harris
Virginia
Electrical,HVAC, Technical Trainer
that would mean metal to metal to me.
The screw penetrates the yoke then spring on the back of the yoke and the screw inserts into the box and completes the bond.
The same thing would apply in 25o.146(A) when you remove the insulating washer off of a regular receptacle. When the screw is drawn up and contacts the box the bond is complete.
Gregg Harris
Virginia
Sorry I should have said completes the ground for the receptical not the bond.
