bfresh
New member
- Decatur Illinoiis Macon County
Can parallel feeders from 2 seperate 200 amp circuit breakers feed a single 400 amp panel.
i
, and another being the prohibition on using Cbs or fuses in parallel.
i
So how does Siemens get away with a residential panel with a quad breaker ( 4-100 amp ) making a 200 amp?
That is different and manufacturers are not required t follow NEC. The OP has 2 runs that are not parallel in that they don't begin and end at the same place.So how does Siemens get away with a residential panel with a quad breaker ( 4-100 amp ) making a 200 amp?
