How many wires are permitted on a standard duplex receptacle?
Smart $
Esteemed Member
Ohio
You mean you can't put one wire in each of the holes on the back and another one wrapped around the screw?:)
Follow up...
Had to back the screw out a tad to get both back and front wires. BTW, those are #12.
... I have not yet seen a crimp connector that naturally fit under the screws; some modification or extreme deformation seems necessary.
The right size helps. Not the wire end... the terminal end. I'm fairly certain the screws are #8. The terminal end in picture would accommodate a #10. "They" do make different size terminal ends.
...however the other style where you wrap the wire can only have one per screw.
No loops... :p
Hv&Lv
Engineer/Technician
Clockwise?
No. When I went to pull the outlet out one wire came off. I wasn't going to put it back like that, so it took longer than expected to fix a problem. All I wanted to do was look in the box.
jxofaltrds
Inspector Mike®
Mike P. Columbus Ohio
ESI, PI, RBO
Follow up...
No loops... :p
Hope this was a 22.5 CUIN box!
XOKO
Rocky Point, NY
wires on a receptacle
OK guys . . . we're going a little astray here. I think Dennis covered it earlier. Wirenutting the neutrals and a single white to the Duplex Receptacle and whatever is provided for the blacks - be it 2 screws, pressure plates or back stabs.
The positive leads do not have to be wirenutted. Thanks for the comments KO
don_resqcapt19
Illinois
retired electrician
The neutral only has to be pigtailed when it is part of a mutli-wire branch circuit.
Smart $
Esteemed Member
Ohio
Question on interpretation...
Where a multiwire branch circuit has split off to a two-wire portion of the circuit, can the grounded conductor be connected through a receptacle's terminal(s)?
templdl
Wisconsin
Reliability of push-ins?
From an efficiency point of view using the push-ins should save time.
What are your opinions about the reliability of using the push-ins? And if it is used as a feed through device which carries the load of the down stream devices?
Even though they are UL listed but would the push-ins be prone to the possibility of more failures?
