Jerseydaze
A customer of mine is getting an above ground pool he doesn't want to dig and would like me to run pvc on fence does anyone see why I can do that code wise?
I see nothing that would prohibit it...mind the expansion of your PVC.A customer of mine is getting an above ground pool he doesn't want to dig and would like me to run pvc on fence does anyone see why I can do that code wise?
Check lowes or depot it's vinyl not PVC
Same thing... (polyvinyl chloride)
As long as the pvc pipe can be supported properly then there should be no issues. I have never seen a pvc fence. I assume there is some rigidity to the structure
I can't imagine that will look good after a few years in the sun, esp in the southern areas.
