wiigelec
- Red Desert
This is becoming a hot topic for me so I would like to solicit the membership for opinion, experience, and information on the following:
Using air switched fused motor contactors (5kV) for interruption of phase-ground and phase-phase faults in a large (200+ hp) motor circuit using an instantaneous (50) relay device.
Let me offer three methods and get some feedback:
Method 1) Always employ the 50 relay device to use the motor contactor for interruption of P-G and P-P faults.
Method 2) Employ the 50 relay device on a case-to-case basis only after performing a short circuit analysis and determining the motor contactor is rated for the available fault current.
Method 3) Never use motor contactor to interrupt P-G and P-P faults, always coordinate with the fuses.
So which of the above methods, or any additional method, do you use when it comes to instantaneous P-G P-P fault interruption in a fused air contactor motor circuit?
Thanks
Thanks
