I have been made aware of a problem recently where a voltage dip/sag at a facility is causing the motor overload relay to trop on overcurrent. I'm still waiting on more details but it appears that when the voltage dip occurs and the motor is running, the motor current increases and trips the motor protective relay on the 51 time delay function. The motor is a 4.16kV motor which I believe is a 200hp motor but again still waiting on more details.
ve been asked whether or not the relay setting can be adjusted in order to ride through this nusiance tripping. The relay pickup is set a 1.0X FLA b/c it was not known whether or not the motor had a S.F. greater than 1.
I'm thinking it is possible to adjust the relays time delay portion of the overload curve but I'm not sure if this will be enough to solve the problem or even the right solution Raising the time delay (while keeping it below the thermal damage point of the motor) will provide a longer tripping time for an increased current and may allow the motor to ride through but I"m not sure if this is the correct solution. The voltage dip seems to be short in duration from what I'm told, but if it lasts long in duration say several seconds, I'm not sure that adjusting the time delay would have any affect.
I'm curious if others have ran into this situation before and what they have done.
Thanks
Thanks
