I?ve seen in a spreadsheet form, a tool that will calculate among other things ?Current?& ?Resistance? of a Delta 3-Phase Heater Circuit. At our facility most of our heater circuits are 480Vac 3PH Resistive type. Ideally, we try to balance the load by installing similar wattage heaters across each phase, making calculation of the current straight forward (I = P / (1.73*480)). For instance 3 x 1500Watt heaters in a delta 480 circuit: I = (4500 / (480*1.73)) = 5.42Amps in each leg Ia, Ib & Ic. The calculation gets more complicated as the wattage between phases or the numbers of heaters vary.
Also in a similar spreadsheet form, if you don?t know wattages but can measure the phase to phase resistance, this information can inserted into the spreadsheet and phase currents can be calculated.
If anyone can provide or has seen such a tool on web, I?d appreciate it.
