Coastalguy1
- Virginia Beach, VA
I have a 26amp 120v lighting load which I want to control with a single pole switch. What size contactor do I supply and what breaker size?
thanks
thanks
26/.8 = 32.5A, so you need a circuit rated 35A minimum and a 35 or 40A breaker, so thereby a contactor rated to that circuit size.
Yes, but keep in mind that the contactor has to be protected by the upstream device. If he ends up using a 40A breaker and the contactor is only rated 30A, technically it's a problem for that contactor.I agree with the 35 amp conductor and breaker - unless this for some reason is not a continuous load - lighting generally is though.
I don't think the contactor needs rated 35 amps as long as it is not rated less than the load it is connected to. Keep in mind the contactor likely has a resistive load rating as well as an inductive load rating.
Or two circuits & two single pole switches and no contactor.or maybe two 20amp circuits thru a 2p contactor ???
thanks
What kind of lighting fixtures are we talking. If its more than a 20 amp circuit it has to be heavy duty lampholders, article 210.23(B)
I suspect he is using a double pole contactor
No code reference other than the "suitable for use" rule, but I was just shooting from the hip. Here are the specs for the Sq. D 8903 contactors.Do you have a code reference in mind for that, in general switching devices are only required to be rated for the load they are controlling.
15 amp light switch on a 20 amp circuit etc.
http://static.schneider-electric.us/docs/Motor Control/Lighting Contactors/8903CT9701.pdf
There's a chart on page 12, lower left, showing the maximum CB size for each rating of contactor. Turns out on that specific one, a 30A contactor can be protected by a 40A breaker. But not a 50A, there is a limit.
This is probably not totally true but I thought fuses had a faster response time than breakers???? Not sure why that would matter.Interesting that if I use fuses I am not limited.
thanks
Your question is a little confusing. Putting a 17.5A load on a 15A breaker would not be a good idea but I don't think that is what you are asking.I have a similar situation. We have a photocell of 2100W, which means 17.5A. Previously somebody put 20A breaker on this circuit, is it ok? Or do we really need a breaker which is less than 17.5A?
