3 Way Switching
Gac66610
Kansas
Me too, I used to use two wire for travelers. How are you running the switchleg and neutral? If your feeding it on one end and switching it on the other that means you have a single lead somewhere else. (to and from the light)
well, a 2 wire traveler and a 2 wire feed, switch leg at either side of traveler. i didnt state all that sorry
when i use a 3 wire traveler i use the white and send the neutral then switch leg at the end of it
