In a mobile home park the service equipment is located 100' away from the mobile home. The required disconnect is installed within 30' of the mobile home. My question is there still an exception that allows you to not run an EGC between the service and the disconnect?(There will be a 4th wire run from disconnect to MH and ground rod driven and bonded to disconnect) If not if your just replacing the disconnect and the 3 wire feeder is already run do you have to run the 4th wire? Could you supply code referance for this please. Thanks
