Alwayslearningelec
- NJ
- Estimator
Does a construction schedule that is issued with a bid become part of the contract?
YES. The reason you received the schedule during the bidding process is to insure you have the manpower requirments to get the job done in time. Weve gotten schedules with the bid package before and its usually a sign that you need to adjust your labor units because there may be some overtime involved.
I will be a little more facetious. The only things that become part of the contract are what is in the contract. That said. bid documents and requirements are so varied that there is no way you question can be directly answered. Here are a couple of situations.
The bid has specs. The bid has a bid bond and is legally binding. The specs state that the "construction schedule must be adhered to" Then you can be guaranteed that the schedule will become part of the contract. Now the rub. You were not actually given a schedule. You must make sure that you clearly state that in your bid. Regardless of whether the recipeint likes it, or even allows exclusions, you have to or you can be screwed.
Same as above, schedule was provided. The job starts late. Then the schedule is still legally binding, but as long as you document the slippage, you are only responsible for eleapsed time and are entitled to compensation if the powers that be accelerate. However, if the job starts late, but the start date on teh schedule is before you sign the contract, then you better make the adjustment before signing. Then you are back to the first.
The bid is informal. All of the above does not leaglly apply, but it is all about relationships. You may not be obligated, but the GC who you work with may be. So be careful.
my view is get some illegal advice before signing any document
A lot of jobs the GC quotes their own schedule. You may be bidding the same job to 3 different GC's, each with their own schedules.
I usually exclude overtime and assume a "normal" schedule
Get some legal advice too.......:thumbsup:
One contract I looked at had liquidated damages of $1000 a day. So in mine I simply added $1000 a day bonus for every day that I was ahead of schedule. They waved the liquidated damages.
