stockexpert
Have to ask this question here since I'm not sure where to ask it anywhere else (at this time).
To make a long story short, we pull MV cable underground (that is our distrubution system). We seem to have splices that fail every other year?! I have argued that we should pull the cable "all the way" through from one switch/transformer to the other switch/transformer but everyone says "you can't pull the cable through manholes straight through..it needs to be spliced."
Anyone have any ideas on this?
After several repeated failures, I am contemplating shutting down all power on all cables in a manhole instead of having guys work on de-energized cables with energized cables above or below. Otherwise, there is just too much risk.
THanks!
THanks!
