Alwayslearningelec
- NJ
- Estimator
When a box is listed as "cast type" is it always cast "IRON"? Thanks.
Yeah I was just thinking.... cast means no seams so to speak, right? Thanks.
To best of my knowledge cast means poured into a mold and left to cool or set. End result is one piece. Can be any material that will pour and then set somehow. To specify that it is iron it is called "cast iron"
There is Mallable, Copper Free and Aluminum.
Look in the OZ-Gedney catalog
Perhaps by definition... not common usage. In trade jargon, plastic and other non-metal parts are referred to as molded, manufactured by the process of injection molding. One usage example is the molded-case circuit breaker.If you want to be technical, PVC fittings are cast, too.
You have never been into a die cast foundry, have you?
The metal is not poured, it is injected, or 'shot' into a die. The temperature of the die is kept constant using oil heaters and water coolers. The shot takes less than half a second and about 3 seconds later the die opens and the part it taken out. The part is cooled and inspected, placed on a conveyor or rollers and then the process is repeated. 1000 shots in an 8 hour shift is not uncommon.
