You would need a lot more information than just the state and service size to get a price.
What is needed? Need to set a pole or furnish and set a pedestal? How much trenching is involved? Even the cost of permits and labor may vary from a larger city to rural area.
If this is a mobile home park the service is normally allready there and all that's needed is a feeder from the disconnect to the panel. But if it's out in the country there is no telling what will be necessary to get power to the mobile home.
If there is no trenching that means it must be a wood sided (at least not metal) mobile home and you are going to set the disconnect and mast on the mobile home much like a house. Still need to be grounded ( couple of ground rods). PVC run for feeder cable, short run, LB under and maybe one to turn up.
I'm thinking that east TN and north georgia would be about the same. I'll guess between $1200-$1500. If you find someone that really needs the work maybe a little cheaper.
