- NE Nebraska
This is somewhat the situation that has come up in other threads recently where there has been disagreement of what is a separate building or structure.
In this case most would say these cabins were separate buildings, if they are the rules are pretty clear.
What if they were just posts with a single receptacle mounted on them?
If they are separate structures they require a disconnect rated for service equipment, and a grounding electrode.
If they are on same property as a dwelling they still require a disconnect but a simple snap switch is acceptable.
I see posts with receptacles mounted on them all the time with no disconnect. Are they all wrong?
