cord and plug
gndrod
Ca and Wa
Hey guys, what do you think about have a receptacle terminated inside the wall on one end and terminated on a metal box with a cord and plug to be connected to an UPS inside a Data Cabinet at the other end?
Hi enrique,
I am trying to wrap my brain around the description you gave. Is the receptacle device inside a box in the wall a compliant installation? And is the other end terminated "on" a metal box with a cord and plug to be connected to an UPS inside a data cabinet have a compliant through the wall transition into the cabinet configuration? Maybe a reword description can help for a forthcoming answer.
gndrod
Ca and Wa
sorry i did not describe it better. let see if a picture help
Looks okay for a rack equipped line connection from the wall conduited receptacle. I am not sure of how the internal rack destination grounding is compliant as the detail view is cut off at the top. A schematic/wiring diagram would even be a better description.
