Stranded Ground Conductors
The "Impedance" noted is, in the case of many grounding conductors, more related to something called "skin effect" where high freqencies generated by the fast rise times of pulse currents (Fourier series components) travel along the outsides of the conductors rather than through them. Therefore, the more surface area the better, which stranding provides. But there's also the matter of practicality, in terms of handling, cost and the frequencies of concern. Unless you're dealing with Signal Reference Ground Grids for something like supercomputers (still a matter of debate in the industry as to usefulness), using something like welding cable (very high strand count and surface area) is gross overkill. Stay with standard electrical stranding unless someone with real credentials has specified otherwise. (Lots of "theorists" out there who call for absurd things they're not paying for without justification.)
