In a residental setting with the POCOS meter on the outside of the house and your 200 amp main breaker panel inside the house. What is your preffed conductor material and why? Say less than 12ft of conductor overall. I have been using AL. The wire comming into the meter is aluminum and it is cheaper and I am asking to find out if it is good enough. Or should I switch to CU.
Thanks
Thanks
